Change a specified RADIUS server value without having to delete the server and recreate it again.
    enable
    configure terminal
  2. Modify a RADIUS server:
    radius server host WORD <0–255> used-by {cli|eapol|endpoint-tracking|snmp|web} [acct-enable | acct-port <1-65536> | enable | key WORD<0-32> | port <1-65536> | priority <1-10> | retry <0-6> | secure-enable |secure-log-level <critical | debug | error | info | warning> | secure-mode <dtls | tls> |secure-profile WORD<1-16> | timeout <1-180>]
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#radius server host 4717:0000:0000:0000:0000:0000:7933:0001 used-by snmp port 12 retry 5 timeout 10 enable
The following table defines parameters for the radius server host command.
Variable
Value
host WORD<0–113>
Configures a host server. WORD<0–113> specifies the IPv4 address, IPv6 address, or fully qualified domain name (FQDN). If you use an FQDN, you must also configure the switch to use DNS.
acct-enable
Enables RADIUS accounting on this server. The system enables RADIUS accounting by default.
acct-port <1-65536>
Configures the UDP port of the RADIUS accounting server. The default value is 1813.
Important:
The UDP port value set for the client must match the UDP value set for the RADIUS server.
enable
Enables the RADIUS server. The default is true.
key WORD<0–32>
Configures the secret key of the authentication client.
port <1-65536>
Configures the UDP port of the RADIUS authentication server. The default value is 1812.
priority <1–10>
Configures the priority value for this server. The default is 10.
retry <0–6>
Configures the number of authentication retries the server will accept. The default is 1.
secure-enable
Enable RADIUS Security (RADSec).
Specifies the log severity level. The default is error.
Specifies the protocol for establishing the secure connection with the server. The possible values are:
  • dtls - Datagram Transport Layer Security (DTLS) encryption over User Datagram Protocol (UDP)
  • tls - Transport Layer Security (TLS) encryption over Transmission Control Protocol (TCP)
The default is TLS.
Important:
To avoid TLS handshake issues if the switch and RADsec proxy server run different versions of OpenSSL, manually force TLS version 2 negotiation through the RADsec proxy by adding the following text to the radsecproxy.conf configuration file:
tls default{
     TlsVersion TLS1_2
secure-ocsp
Enable RADIUS Online Certificate Status Protocol (OCSP) checking.
The default is disabled.
Configures the secure profile for the server.
timeout <1–180>
Configures the number of seconds before the authentication request times out. The default is 8.
used-by {cli | eapol | endpoint-tracking | snmp | web}
Configures how the server functions:
  • cli—configure the server for CLI authentication.
  • eapol—configure the server for EAPoL authentication.
  • endpoint-tracking—configure the server for Endpoint Tracking authentication.
  • snmp—configure the server for SNMP accounting.
  • web—configure the server for HTTP(s) authentication.
The default is cli.
